Iris International - StatSpin Express 4
High Speed Horizontal CentrifugeThe StatSpin Express 4, high speed horizontal centrifuge provides faster turnaround time and greater productivity for your "lean" laboratory. Place it next to any STAT analyzer and serum or plasma gel tubes are ready in just minutes. With only three (3) settings, it is simple to use. Just select the 3, 5 or 10 minute button and press start. No fumbling with settings or the need to readjust the speed. For safety, the lid remains locked until the rotor comes to a complete stop. An audible alarm sounds when the cycle is completed. Samples can be processed as they arrive in the lab; no need for batching, no unproductive time spent waiting for the centrifuge.....you'll have results in minutes. Now you can process as many as eight (8) samples at once for high throughput. The StatSpin Express 4 is powerful. The rugged brushless motor is maintenance free.
FORUMSView All (11)
3Replies4 months ago | 5 min light comes on but nothing works Power unit on, lid locks, 5 min light comes on SOLID, if I push any other buttons it beeps twice and lights go out and no other responses register. I see 5 min error code is when it’s Flashing right ?? For lid lock error? Maybe it’s not registering locked lid? But it is a solid light on 5 min. Thanks Equipment: Iris International - StatSpin Express 4 Reply |
2Replies4 months ago | Locks but no lights , no spin Have this Express4 , it locks lid and beeps twice when powers on, but no lights or reactions to any buttons, any ideas ? Equipment: Iris International - StatSpin Express 4 Reply |
2Replies7 months ago | Front panel assembly swap So I swapped the front panel assembly and now the new piece does not turn on. I checked with the old part and no power there either. The board gets power but the board reset button does not work. Any insight on what steps need to be taken if any when swapping that part. Reply |
- Fast - In just 3 minutes, the Express 4 can produce serum or plasma equal to tubes spun for 10 or more minutes in a conventional horizontal centrifuge.
- Separates gel tubes - rapid separation of gel tubes with flat gel barriers to ensure no cell interference.
- Simple to operate - Just 3 buttons - no fumbling with settings.
- Versatile - Adaptors for 7mL and 10mL tubes come with the unit. It can accomodate tubes from 1.5mL to 10mL.
- Safe - Shield interlock and steel bowl provide mechanical containment for operator safety. UL listed and CE marked.
- Self-diagnostics - Diagnostic error codes indicate imbalance and reduces chance of operator error.
Height | 8 in |
Length | 16 in |
Orientation | Benchtop |
Weight | 22 lbs |
Centrifuge Type | High Speed |
Width | 13 in |
Spin Parameters:
- 3 min: 180 sec @5,100rpm/4,000xg
- 5 min: 300 sec @5,100rpm/4,000xg
- 10 min: 600 sec @4,500rpm/3,100xg
