Cadwell Laboratories - Easy II
by Cadwell Laboratories
The Cadwell Easy II is an advanced multi-modality system.
Another of Cadwell's ground breaking biomedical instruments, the Easy II is a fully functional totally ergonomic electroencephalogram that is designed for the use in both private offices, clinics, and hospitals. The main advantage of the instrument is its versatility to serve as a full featured EEG in any setting and for a vast variety of exams. These include seizure detection, evaluation to sleep studies, pre-seizure, and even monitoring.    It has 3 small major components: 32 channel headbox, small breakout box for amplifier power connections and excellent photic stimulator.    Acquisition is fast, flexible, and precise. Just a click of a mouse will instantly enter one of 18 events - 10 that are programmed and 8 you can program yourself. Click a button to adjust filters, montages, or sensitivity. The Easy II will mark these changes, plus photic stimulation sequences, on the EEG record for later review.
FORUMSView All (3)
-Jose Ariel Martinez
Sun Dec 21 2025
Need for a new number
I have an Easy II Cadwell EEG device. Purchased 13 years ago. It works flawlessly. The laptop used to perform EEGs doesn't work anymore, If I run the original CD (that usually asks for a specific number). Does this system is still in process? Since this model has been discontinued by Cadwell
-esk
Fri May 26 2017
Deleting old patient files
Deleting old patient files to free up spaceReply
-mminko
Wed Oct 14 2015
Recorder download cable
Where do you connect the Cadwell recorder download cable to a laptop computer when performing an ambulatory EEG?
SERVICE COMPANIESView All Electroencephalograph (EEG) Companies
[list]  [*] It runs on any Computer XP or Windows 7 (32 bit)  [*]Dual-purpose PSG with EEG for night and day use.     [*]Advanced computer hardware options suit any lab.     [*]32 channels     [*]4 or 8 DC channels     [*]Internal oximeter     [*]Q-Sleep® features     [*]CAPS Viewer     [*]Scorer-to-Scorer® QA module     [*]EDF Data Export Tool     [*]Complex network solutions for ultimate flexibility.     [/list]
Height4.5 cm
Length 15 cm
Weight1.4 kg
Width23 cm
