Leading Edge - Centri-V 1586
by Leading Edge
Horizontal separation offers many advantages over traditional fixed-angle separations, including tighter straight-line gel separations to reduce re-spins and re-mixes. The 1586 spins test tubes, up to 16.5 x 128mm, at speeds up to 5,000 RPM, with microprocessor speed control. G-forces up to 4,100 g’s will produce platelet-poor plasma in minutes. Smooth acceleration and deceleration keep fecal sample's coverslips in place.
[list] [*] Process Fecal, Blood, Urine and Microhematocrit samples [*] Maintains constant temperature in centrifuge chamber through innovative vortex ventilation system [*] Wide mouth Stainless Steel chamber for easy clean-up [*] All digital display with anti-spill touch-pad controls, digital timer and tachometer [*] Life-extending, brushless, temperature-controlled motor [*] Whisper quiet (‹70dB) [*] Process Microhematocrit samples with optional Hematocrit Tube Carrier [/list]
Height | 13 in |
Length | 18 in |
Orientation | Benchtop |
Maximum Speed | 5000 rpm |
Width | 14 in |
