Siemens - Biograph 6
The Siemens Biograph 6 Tomograph is a whole-body tomograph designed for the purposes of oncological imaging and diagnosis.
With a single noninvasive procedure, the biograph produces remarkable images, inherently registered, that reveal detailed anatomy and biological processes at the molecular level.
0Replies6 years ago | Biograph 6 NETSpot Protocols What protocols do you use for a NETSPot imaging using a Biograph 6? Minimum standards for a scan?Reply |
- Syngo Acquisition Workplace and MI Workplace
- Integrated panel display
- 70 cm gantry aperture and unique reinforced cantilever designs
- Maximum patient weight of 204 kg (450 lbs)
- Perform routine whole-body scans with injected dose of 5 mCi
- Pico-3D ultra fast electronics for decreased dead time and high signal-to-noise
- Three-dimensional display of organs with a large axial view
- 50 cm scan field of view in all scan modes
- Slice thickness: 1,1.25,2,3,5,6,8 and 10mm, Spiral CT, and Dynamic
- Significant x-ray dose reduction (up to 65 %) possible for all body regions
- Easy-to-use scan protocols
- LCD flat screen monitor
- Intercom with user-programmable patient instruction system
Crystal Thickness | 83 cm |
Slices | 6 |
Weight | 5137 lbs |
Scintillator Type | Lutetium Oxyorthosilicate (LSO) |
Axial Field-of-View (AFOV) | 162 mm |
Gantry (Max. Clearance) | 70 cm |
Patient Weight Capacity | 450 lbs |
Minimum room size (INSTALLATION NEEDS) 7.9 x 5 m, scanner room; 3.2 x 4 m, operator room
