Philips - Gemini 16
by Philips
 PET/CT Scanner
Expanse technology helps reduce patient anxiety and claustrophobia while enabling independent operation of either the CT or PET components. The Philips Gemini 16 PET CT scanner combines the anatomical data power of the Philips Brilliance CT 16 scanner with Philips ALLEGRO PET metabolic data together in fused images, allowing users to detect and diagnose even very small lesions. Each refurbished Philips Gemini 16 PET CT scanner offers exceptional 3D image quality, while its PIXELAR detector maximizes true counts and reduces scatter, resulting in excellent homogeneity and stability.
-CMM-1973
Thu Feb 16 2023
Recon CIRS issue
Having a wierd problem with a CIRS, will complete scout but ultimately fails stating Check resources from IRS ok Get ready from IRS failed [5]!!! Event: check resources failed stat=2009 " check resources failed for recon only step 3" Any help appreciated
Equipment: Philips Gemini PetCT
-DSX57
Fri Oct 17 2014
heath exchanger
how to ad oil to heat exchanger
  • 190 cm scan length
  •  Philips OpenView dual gantry aperture with 63-cm patient port
  •  Full 3D PET acquisitions
  •  5 min/bed reconstruction time reduces patient throughput
  •  <5mm spatial resolution to detect extremely small lesions
  •  MRC tube with rapid heat dissipation for zero delay between exams
  •  DoseWise and Smart Beam Management blocks X-rays that do not add to image quality
  •  Fade MIP algorithm to differentiate overlying structures
  •  Comfortable table with easy access for wheelchair patients
Slices16
Maximum Scan Range162 cm
Gantry (Max. Clearance) 70 cm
