GE HealthCare - Corometrics 170 Series
by GE HealthCare
Delivering reliable, and accurate fetal monitoring.
Whether you perform antepartum fetal monitoring in an office setting or in the hospital, Corometrics ™ 170 Series Fetal Monitor can help. You can trust our fetal monitors to help you improve the standard of care for your expecting mothers. We designed these compact, lightweight monitors to help you effectively and efficiently care for mom and baby by accurately and noninvasively tracking baby’s heart rate for non-stress tests.
3RepliesWed Jun 25 2025 | Corometrics 172 not giving consistent heart rate readings; TOCO appears normal; Had one of our customers test the monitor on a pregnant nurse, using two transducers; neither one could consistently measure her HR or the baby's. Tested a different machine which worked fine. Used a fluke fetal HR simulator: the machine would sometimes read the correct HR briefly, but would randomly shoot up or down. Set at 120bpm, it would read that for a second, but without being moved or disturbed in any way, would randomly shoot all over the place between 80 and 220bpm on the display; this is with the setup setting completely still. Does anyone know what this indicates? Main board bad? Or simply a connecting ribbon needs replaced, something like that? Reply |
7RepliesMon Jan 30 2023 | error code = 2 what is the meaning of this error code how to fix please Equipment: GE Healthcare - Corometrics 170 series Reply |
2RepliesMon Sep 20 2021 | no sounds we recently had machine services and printer part replaced. no sound since. any thoughts? Reply |
| Height | 14.6 cm |
| Length | 25.4 cm |
| Weight | 3.6 kg |
| Width | 42.5 cm |
