Siemens - SOMATOM Perspective
Enter the Business Class in CT.SOMATOM® Perspective is an advanced CT scanner that addresses challenges of modern healthcare without compromising your clinical results. This scanner can help manage your financial performance while allowing you to focus on easy and effective care.
FORUMSView All (10)
3Replies4 years ago | Service Docs needed I need service docs for the Siemens Perspective. Thank you... I tried to download from Siemens Documentation Library. They are not avalible.. Reply |
6Replies4 years ago | filament adaptation aborted by error can anyone help me how to fix this error ?? my CT SCAN can't be used Reply |
3Replies5 years ago | Need service key for 2019 Service key is required DICOM node in following machine Siemens - SOMATOM Perspective 64 slice CT scanner Thanks Reply |
SERVICE COMPANIESView All CT Scanner Companies
VIDEOS
Siemens Sensation CT 4 part se...
- Manage your financial performance - Enhance patient care affordably with a system engineered to help you reduce cost and that is supported by innovative, cost –effective service solutions.
- Widen your clinical portfolio - Innovative technology and system design open doors to expand your advanced CT imaging with more applications – enabling the potential for better patient care and improved daily routine
- Ease your working day - SOMATOM Perspective keeps your clinical needs in view through streamlined workflow, built in efficiency features and technology innovations.
- eMode - The unique eMode allows you to operate the scanner in the most patient-friendly and financially-efficient way – with one click
- Illumination Moodlight - the most evident design element of the SOMATOM Perspective, creates a comfortable environment and can easily be adjusted to personal preferences.
Type (configuration) | Multislice |
Gantry (Max. Clearance) | 68.5 cm |
NEWSView All
New Siemens SOMATOM Perspective CT Scanner Focuses on...
System marries high image quality and low radiation dose with price pressure sensitivity
