Advertisement
Drucker - Horizon mini-B 642B
Manufactured by Drucker
The Horizon mini-B, model 642B, is a single-speed centrifuge designed for the doctor’s office or small lab. Its compact design minimizes its footprint, leaving more room on your counter. The unique horizontal rotor design allows for the test tubes to be inserted into the centrifuge at a convenient 45 degree angle. They are then gently rotated to a full horizontal position as the motor accelerates.
QUESTIONS & ANSWERSView All
Be the first to ask a question about this equipment
DOCUMENTS / MANUALS
PREVENTIVE MAINTENANCEView All
Be the first to submit a preventive maintenance post about this equipment
  1. Full horizontal separation for test tubes up to 10mL
  2. Compact design uses less than 1 sq. ft. of counter space
  3. Horizontal Rotor comes standard with centrifuge
  4. ETL Compliant to ANSI/UL Standards
  5. Single-speed: 3,380 RPM/1,600 x g, Horizontal (Standard)
Maximum Speed3380 rpm (+/- 100)
OrientationBenchtop
Height8.5 in
Length 12.5 in
Weight18.5 lbs
Width11 in
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
