Datascope - Accutorr Plus
by Datascope
Vital Signs/Multi-Parameter
The Datascope Accutorr Plus Multi-Parameter Patient Monitor is a compact, lightweight monitoring solution designed for screening, preoperative, and postoperative care environments. Weighing under five pounds, this portable vital signs monitor is well suited for biomedical engineers and healthcare teams who require accurate, reliable patient monitoring in space-constrained or mobile clinical settings.
The Accutorr Plus provides continuous measurement of non-invasive blood pressure (NIBP), oxygen saturation (SpO‚), and pulse rate, with optional configurations for temperature monitoring and Nellcor™ or Masimo™ pulse oximetry technology. An integrated recorder module supports detailed documentation and data review, enhancing clinical workflow and equipment management. With flexible feature options and dependable performance, the Datascope Accutorr Plus is an effective solution for biomedical engineers supporting perioperative and general care monitoring applications. (Generated by AI)
FORUMSView All (15)
-shaima
Thu Jan 05 2017
not charging
hi , my datascope is not charging ,i checked the charging circuit it was ok ,but when i put a new battery its not charging ??
-shaima
Tue Jan 03 2017
Datascope acctuorr puls
My datascopeaccutorr puls ,is doing the initial test and count until reaches zero ,then it stoped and not working , what i should do ?! Reply
5
-shaima
Tue Dec 06 2016
Save my Batteries
Hi .. What is the perfect way to save my battery ,it should be pluged in AC power the whole time , or this will effect the life time of the battery?! Reply
  • Lightweight, portable design (weighs less than 5 lbs) for easy mobility in preoperative and postoperative areas.
  • Non-invasive blood pressure, SpO2, and pulse rate measurement for comprehensive patient monitoring.
  • Configurable technology allows adjustments for patient size, interval time, alarms, inflation pressure, audio levels, and more.\
  • Large, easy-to-read display with customizable controls for enhanced usability.
  • Quick-connect, single hose fittings for convenient setup and use.
  • Flexible databases for customizable settings and patient data management.
  • IV pole or bed rail attachment for versatile mounting options.
  • Battery operation ensures mobility and portability in various clinical settings.
  • Stores up to 100 readings, instantly accessible for historical data review.
  • Predictive thermometer module for enhanced temperature monitoring.
  • Printer module for instant documentation and patient record generation.
The Datascope Accutorr Plus is an ideal solution for biomedical engineers and healthcare providers seeking a reliable, portable, and easy-to-configure multi-parameter monitor that offers comprehensive patient care with minimal setup time.
