Valleylab - Force 1B
by Valleylab
[list] [*] Monopolar and Bipolar Outputs [*] Audible and Visual Arms, including REM(TM) Fault Indicator [*] REM(TM) (Return Electrode Monitoring) (Standard) [*] 300 Watts Output - Cut, 120 Watts - Coagulation, 70 watts - Biopolar [/list]
1ReplyMon Oct 22 2018 | Preventive Maintenance inspection for a Valley Lab Force 1B I downloaded the Valley Lab Force 1B Testing Procedure pdf. Is this what you do for a preventive maintenance check?Reply |
1ReplyWed Jun 28 2017 | I am searching for a Valleylab Force 1B Power supply board Anyone knows where i can get one? Had one but all power transistors were burned during usage, did not blow, only started to smoke and operator stopped using it rightr away. Motherboard is burned black. Better get a new one than risk changing piece by piece.Reply |
2RepliesSat Jan 14 2017 | Dr. C My Force 1B unit which I have had for years suddenly became nonfunctional with failure of the REM light to go off despite adequate connections. Any suggestions? Reply |
| Weight | 15 lbs |
| OutPut Frequency | 500 kHz |
