Valleylab - Force 30/40
The Valleylab Force 30 / 40 is a digital electrosurgical unit that displays power and is very flexible in terms of cautery and procedure capabilities. It will perform standard functions including blend for both cut and bipolar modes.
FORUMSView All (12)
1Reply2 years ago | Force 30 116 Error We're getting the above error on our Force 30. Doesn't matter if there's an accessory plugged in or not. Have stripped the unit down, visually inspected it, blown it out with compressed air and reassembled. No change. Also occasionally get the 110 error too. Anyone have any experience with this? 110 appears to relate to the buttons on the front panel. 116 refers to one of the accessory buttons being stuck on. Context: Lab test machine - not in surgical use. Reasonably old but gets very little sustained use. We use it as an RF source for testing implements.Reply |
2Replies2 years ago | Calibration i want to calibrate valley lab force 40 please guid me how i calibrate my force 40Reply |
0Replies3 years ago | Power supply resistors incorrect. Force 40 unit. Several of my resistors are incorrect compared to the manual's parts list. R97,98 150 ohm, 50W according to the manual, unit contains 150 ohm and 100 ohm 50w resistors. The manufacture of both resistors is the same suggesting factory OEM. R14,84 100 ohm 1/4 watt according to the manual, when the unit contains a 56 ohm resistor much bigger than 1/4 watt in the r84 slot. R14 is correct according to the manual at 100ohm 1/4 watt. The PCB painted outline for 84 is much larger than a 1/4 watt resistor, suggesting this is the factory OEM resistor. Finally R69,70 are 510 ohm 1/2 watts according to the manual but 69 is a 4.6k ohm possibly 2watt? based on size. 70 was burnt and I cannot confirm size but the outline confirms it should be much bigger in wattage than the manuals stated 1/2 watt. Attempting to replace R70 with a 4.7k ohm 2 watt does nothing advantageous. I am getting codes #3 #86 #100-104 #111-118 #122 #124 Any help on the color code of R70 would be helpful. 4.6k ohm 2 watt resistors look to be unobtainable on the resistor market. Reply |
- Automatic activation impedance 40-100ohms
- Automatic deactivation impedance: 2000ohms
- Time delay range: .1 to 5.1 seconds
- Activation tone: 45 to 65 dBA
- Alarm Tone: >65 dBA
Height | 7.8 in |
Length | 11.9 in |
Weight | 20 lbs |
OutPut Frequency | 500 kHz |
Width | 16.1 in |
Output Waveform:
Cut: 500kHz sinusiod
Blend 1: 500kHz bursts of sinusiod @50% duty cycle, recurring @ 31.25 kHz
Blend 2: 500kHz bursts of sinusiod @37.5% duty cycle, recurring @ 31.25 kHz
Desiccate: 500kHz damped sinusiodal burst with a repetition frequency of 250 kHz
Fulgurate: 500kHz damped sinusiodal burst with a repetition frequency of 62.5 kHz
Spray: 500kHz damped sinusiodal burst with a repetition frequency of 31.25 kHz
Standard Bipolar: 500kHz sinusiod
Precise Bipolar: 500kHz sinusiod
