Mindray - AS 3000
Anesthesia Gas Machine
After nearly half a century of listening to anesthesia providers, Datascope Patient Monitoring has developed a simple to use, full featured anesthesia system, offering comprehensive safety features, for use with a wide range of patients. Finally, simplicity has returned in a cost-effective traditional package, with the AS 3000 Anesthesia System. The efficient design of the AS3000 makes it a perfect fit for even the busiest operating rooms. The AS3000 is brimming with features which are typically options on most anesthesia delivery systems.
1Reply3 years ago | Safety valve test Failed Maquina de anestesia Datascope AS3000 Hi, can u help me with this test, is failed and I can´t use automatic mode. Please, help. Hola, no me pasa el test de valvula de seguridad, alguno sabe como lo puedo solucionar, el manual de servicio no me ayuda mucho. Gracias. Reply |
1Reply11 years ago | scavenging system When does the scavenging system need to be checked? How often and to what extent? Reply |
- Multiple ventilator modes including: Pressure Controlled Ventilation (PCV), Pressure Support Ventilation (PS), Synchronized intermittent mandatory Ventilation (SIMV) and Volume Controlled Ventilation (CMV)
- The warmed breathing system (35°C) virtually eliminates internal condensation
- The auxiliary O2 / air flowmeters provide a built-in method of regulating O2 concentration
- Remote, dedicated 10.4" color display, adjustable for maximum visibility of ventilator information
- Standard, dual flowmeter for oxygen, nitrous oxide and air
- Traditional CO2 absorber system uses standard prepacks or loose fill absorbent
- Navigator knob and touch keys speed access to commonly used functions
- Fresh Gas Compensation ensures consistent tidal volume when changing fresh gas flow rates
- Three full-width, spacious drawers allow complete visibility of contents
- Interactive system checks advance rapidly for immediate equipment use
- Automatic Compliance Compensation ensures accurate tidal volumes with a wide range of breathing circuits
Height | 54 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 27 in |
Vaporizers (Max) | Two |
Weight | 326 lbs |
Inspiratory Flow (max) | 75 L/min |
Vaporizer Type | Variable-bypass |
Vent Modes | Manual/spontaneous, CMV, PCV, PS, SIMV; for pediatrics and adults |
Width | 65 in |
- Top Shelf - 65 x 35.2cm/ 25.6 x 14in
- Drawers - 12.1 x 45.2 x 30.5cm/ 5 x 9 x 12in, 3 equal sizes
- Power required - VAC 120/220
- Auxillary Electric Outlets - 4
