Colin Medical - YM6000
The YM6000 is a sophisticated monitor using the best technologies.The dynamic linear deflation NIBP module guarantees greater patient comfort, shorter measurement time and improved accuracy for all adult, pediatric and neonate patients. The new SpO2 module with sensors lets you take full advantages of the ongoing advances in pulse oximetry. Up to 24hrs tabular and graphical trends show all parameters to support clinician's decisions whenever necessary. The central monitoring system displays real time and dual waveforms (Standard model) or 4 analysis waveforms to enable a single clinician to care for 16 to 32 patients effectively.
1Reply3 years ago | Monitor Housing Assembly Can I buy replacement partReply |
1Reply6 years ago | Standby How do you put the monitor on standby? Reply |
[list] [*] Available parameters include 3 or 5 lead ECG, Respiration, NIBP, Sp02, 2 temperatures, included battery and optional 2IBP, EtC02, and built-in printer [*] High quality 12.1 inch color TFT LCD screen enables you to monitor 6 traces with 10 numerics vital sign clearly even under the most difficult lighting conditions. [*] 6 color coded keys and a trim knob admits clinicians to quickly access monitoring function controls. [*] The optimized 2 packs of Ni-MH rechargeable batteries, a wheeled mobile cart and an integrated top handle ensure continuous monitoring under any transport circumstances. [*] Connectivity to the central monitoring system enables users to receive alarm signal automatically when the patient's condition turns critical. Also the stored event or real time vital sign can be re-called to review and print with any PC printer through the network. [/list]
Height | 305 mm |
Length | 172 mm |
Weight | 5.5 kg |
Width | 341 mm |
Power Requirements: AC Mains 100Vac-240V~50Hz/60Hz, 63-110VA Temperature Range: 15C to 45C ECG Measurement Range: 30 BPM to 350 BPM Respiration Rate Range: 0.3 to 120 breaths/min NIBP Pulse Rate Range: Adult/Pediatric 30 BPM to 260 BPM Sp02 Pulse Rate Range: 0 and 20 BPM to 250 BPM Capnography Range: 0 - 150mmHg IBP Pulse Rate Range: 20 BPM - 250 BPM
