Draeger - Infinity Kappa
Bringing you closer to your patients
Intended for fixed monitoring at the bedside, the Kappa monitor supports all patients from adults to neonates, in all acuity levels. The standard monitor includes a CPU base unit that is compatible with standard medical-grade, flat-panel displays.
FORUMSView All (6)
1Reply7 years ago | re: ECG Output to IABP CS 100 Dear SIr,
What is the output pin configuration x10 FOR CAPA monitor for connecting ECG output to IABP machine?
Regards, Atul Reply |
0Replies8 years ago | Service Manual and Password Hi, does anybody has the service manual for the infinity Kappa monitor? Or can provide me de biomed password and the pasword for change the configuration form masimo to nellcor in the SPO2. Reply |
3Replies8 years ago | Where is the ECG output socket? Reply |
- Flexible bedside monitoring - Supports all patient types, acuity levels, and care areas
- Integrated networking - Can be networked, enabling patient information collected at the bedside to flow through the Infinity Network to the Infinity CentralStation for central surveillance and to the Innovian® patient data management system for automatic charting
- Parameters scale to the patient's needs - Can display a full set of vital parameters – including 3-, 5-, 6- and 12-lead ECG, respiration, ST segment analysis, etCO2, BISx™, EEG, multiple temperatures, invasive and noninvasive blood pressure, and full arrhythmia
Height | 102 mm |
Length | 368 mm |
Pulse Rate Range | 15-300 BPM |
Weight | 8.4 kg |
Width | 368 mm |
