GE HealthCare - CARESCAPE B650
by GE HealthCare
Vital Signs/Multi-Parameter
The CARESCAPE Monitor B650 is a high-performance, multi-parameter patient monitoring system engineered to support efficient patient flow, clinical accuracy, and data-driven decision-making across a wide range of care environments. Designed for scalability and interoperability, the B650 integrates seamlessly into modern hospital networks, enabling real-time physiological monitoring and centralized patient data management.
With an intuitive user interface and flexible modular architecture, the B650 can be configured to meet evolving clinical needs in critical care, perioperative, emergency, and step-down units. Its upgradeable software platform supports continuous innovation, ensuring long-term investment protection and adaptability as clinical standards and hospital technologies advance.
Built for reliability and precision, the CARESCAPE B650 delivers continuous, high-quality patient data to clinicians while maintaining system stability, cybersecurity compatibility, and ease of maintenance for biomedical engineering teams. Its robust design and interoperability make it a strategic asset for hospitals seeking to optimize workflow efficiency, patient safety, and monitoring infrastructure. (Generated by AI)
FORUMSView All (17)
-Dinglis2
Mon Feb 26 2024
B650 data output over USB
Hi everyone. I work with multiple Carescape B650 and we are trying to record ECG data onto a PC for analysis. We have this working on older S/5 with USB to serial cable and using a proprietary bit of software to extract and record
After lots of reading it is suggested that the B650 outputs all data through USB (often just the last port). I have followed all the instructions I can find online about cable types and have tried multiple bits of software on different computers which all claim to work with these monitors, yet I get no output
Is there a setting somewhere on the monitor for this? I can’t see it if there is. Has anyone come across this before or should the data always be transmitted?
I should add a USB keyboard works if plugged in, so the ports are functional
Thanks
-KTM17
Sun Dec 03 2023
Temperature units
My ICU unit just got Carescape B650 monitors and my colleagues and I can’t for the life of us figure out how to change the temperature units from Celsius to Fahrenheit. Help?! Thanks!!
-CBET Neil
Tue Nov 15 2022
error codes
what is 0xHOST1006 error?
Equipment: GE Healthcare - CARESCAPE B650
  • Real-time vital sign monitoring for critically ill patients.
  • Ventilator weaning tools to reduce patient length of stay.
  • Advanced arrhythmia and stroke detection for timely intervention.
  • Seamless integration with ventilators and other devices for a unified system.
  • Enhanced dosing accuracy and early complication detection.
  • Continuous data flow from pre-op to post-op for informed decisions.
  • Consistent monitoring with OR-level measurement parameters.
  • Comprehensive neonatal monitoring with intelligent alarms and minimal noise.
  • Data continuity from transport to bedside for neonates.
  • Rapid, flexible monitoring for trauma patients.
  • Unified patient data access for efficient care and decision-making.
  • Customizable for various ICU settings, including CCU, OR, PACU, NICU, and ED.
