Welch Allyn - 300 Series
by Welch Allyn
Simple and accurate vital signs assessment and continuous monitoring
As a clinician, you are under pressure to improve outcomes, boost operating efficiencies and lower costs every day. It’s a daunting challenge, but one that can be made a little easier thanks to the Welch Allyn Vital Signs Monitor 300 Series—an affordable vital sign monitor that’s both flexible and easy to use.
Like the original Welch Allyn Vital Signs Monitor, the 300 Series helps enhance your productivity by providing automated vital signs before, during and after procedures. The simple, push-button menu operation and bright display allow you to quickly learn and easily obtain the important information you need, so you spend more time with your patients and less time with your equipment.
4RepliesMon May 24 2021 | Problem with NIBP I need help with this monitor, it shuts off completely before reaching the non-invasive pressure limit, I changed the battery. The battery is new and it keeps shutting off, if I set the limit at 160mmHg it shuts off at 155mmHg, if I set the limit at 180mmHg it shuts off at 170mmHg. When I do the NIBP tests it does not turn off but when I go to do the measurement it turns off.Reply |
13RepliesWed May 19 2021 | Problems with NIBP I need help with this monitor, it shuts off completely before reaching the non-invasive pressure limit, I changed the battery.Reply |
1ReplyWed Jan 03 2018 | tensiometer how to calibrateReply |
| Height | 6.6 in |
| Length | 6 in |
| Weight | 5.4 lbs |
| Printer | Thermal Transfer Printer |
| Width | 10 in |
Welch Allyn has selected Clinical Dynamics’ line of AccuPulse NIBP Simulators with CalTables for testing.
