Welch Allyn - Spot Vital Signs LXi
Take vital signs in about half the time. Take patient care to a whole new level.The new Welch Allyn Spot Vital Signs LXi gives more parameters and more options than any other spot-check device on the market, so users can customize it to meet their specific needs.
FORUMSView All (6)
1Reply6 years ago | Error C05 How to repair the BP error C05?Reply |
2Replies8 years ago | NBP not working When the NBP button is pressed, the motor does not come on and the value sits at zero. The device "times out" and shows a C04 error. Replacing the NBP Pump should fix the issue (I assume), but I would like to see if anyone else has had this issue. If so, what did you do to fix it? Reply |
2Replies10 years ago | NIBP calibration software According to tech support, the software has only been tested on Windows XP therefore, they cannot say if it works on 7. Has anyone used the software on a Windows 7 computer? Thanks... Reply |
- SureBP technology measures blood pressure in about 15 seconds as the cuff is inflating—resulting in time savings for users and improved comfort for their patients, pulse rate and MAP included
- Choice of SureTemp Plus or Braun ThermoScan PRO 4000 ear thermometer
- Choice of Masimo or Nellcor pulse oximetry
- Ability to manually enter weight, height, respiration rate, and pain level; calculates Body Mass Index
- Connects to select Healthometer or Tanita digital scales
- 50-reading memory allows retrieval of previous data for review, to print or to download later
- Connectivity-ready
- Error messages gives descriptions and real solutions—not just error codes
- Bigger, brighter LCD display provides greater visibility from farther distances
Height | 27 cm |
Length | 19 cm |
Weight | 3.4 kg |
SpO2 Range | 1-100% |
Temperature Range | 26.7 to 43.3 °C |
Width | 13.34 cm |
Display Resolution: -17.7° C
SpO2 Range: 25 to 240 bpm
NEWSView All
Welch Allyn selects Clinical Dynamics testing device for vital...
Welch Allyn has selected Clinical Dynamics’ line of AccuPulse NIBP Simulators with CalTables for testing.
