GE HealthCare - OEC 9800 Plus
by GE HealthCare
Mobile C-Arm
The OEC 9800 Plus is a mobile imaging system that combines real-time 1k x 1k imaging resolution with a rotating anode X-ray tube and high powered 15 kW generator. This combination helps users see the details they need to see, even in very challenging imaging environments. The OEC 9800 Plus sets the standard for mobile imaging systems by providing image capture, recording and management capabilities comparable to the latest fixed-room fluoroscopic imaging systems at a significantly reduced cost.
FORUMSView All (69)
-Bernard S.
Wed Mar 05 2025
cmos battery reset
How to reset wsp when you replace the cmos battery
Equipment: GE OEC WISP NETWORK INTERFACE
-jose diaz
Thu Nov 02 2023
falla de touch screen
saludos tengo un OEC 9800 que al iniciar me arroja error de pantalla táctil, si alguien me puede oriental con esa falla por favor
-SAMAURELIO
Thu Aug 17 2023
OEC 9800 PLUS SERVICE MANUAL
Good morning, can anyone help me with this equipment. I am in need of the complete service manual including the calibration software.
Can someone help me
Equipment: OEC 9800 PLUS
  • Total redesign of current mobile C-arm equipment featuring 1K x 1K imaging resolution
  • 1K x 1K imaging resolution creates an expanded, more powerful platform.
  • Intuitive touch screen control offers simple system operation so it's easy to use by users of all levels of experience.
  • AutoTrak (TM) feature automatically tracks the subject anatomy anywhere within the imaging field for true point-and-shoot ease of use.
  • Low X-ray dose with high quality images
  • Backlit C-arm control panel to see in darkened operating rooms
  • Operator control panel on both sides of C-arm chassis conveniently located for operator use.
  • Triple the generator power.
  • Lightweight for ease in steering and maneuvering.
Maximum Focal Spot0.3 mm Dual focal spots, 0,3mm/0.6mm
X-ray Generator Power Rating15 Kw
  • Standard features with a 1k x 1k 16 bit image processor.
  • PM Care Platform
  • Standard ESP features plus Real-time DSA and 8 FPS dynamic digital disk.
  • Vascular Platform
NEWSView All
GE 9800 Plus Vs GE 9800 C-Arm – Comparing the Differences
We are frequently asked: “What’s the difference between the GE 9800 and 9800 plus C-Arm?” Well today we thought we would help our customers out by answering this question once and for all.
Device Alert
High-Voltage Bridge Driver May Not Conform to Safety Standards for Clearance and Creepage of Voltage Isolation, Potentially Leading to Loss of Imaging Functionality See attached PDF under Manuals & Resources tab
