Welch Allyn - Propaq Encore
by Welch Allyn
0RepliesSun Jul 05 2015 | error error message Reply |
0RepliesFri Aug 22 2014 | NIBP Issues sometimes the unit is not reading systolic pressure and sometimes the unit is not reading diastolic pressure. Occasionally it will not read either. Put a brand new pump in the unit so i do not think it is that. What could be the issue? Reply |
0RepliesTue Nov 12 2013 | Broken Cases of SCO2 Sampling Lines Does anyone know where I might be able to find SCO2 sampling lines for the Propaq Encore in quantities less than the case? This is my backup monitor which gets little use and I can't justify spending $500+ for a case of sampling lines. These are the Welch-Allyn/Oridion collaborative design sold by Covidien, item #s 010986 or 010987. Thanks. Reply |
| Power Requirements | 100-240 VAC |
| Paper Width | 53 mm |
| Printer | Thermal hot dot |
| Temperature Range | 0 to 40 °C |
Welch Allyn has selected Clinical Dynamics’ line of AccuPulse NIBP Simulators with CalTables for testing.
