Rigel Medical - Uni-Therm
by Rigel Medical
Electrosurgical Analyzer
 The Rigel Uni-Therm is a high-performance electrosurgical analyzer designed for fast, accurate, and safe testing of all modern electrosurgical generators. Featuring a high-resolution, low-inductance load bank, it measures high-frequency leakage, power distribution, and patient plate impedance with resolutions down to 1Ω.
With its large color display and intuitive user interface, the Uni-Therm guides users through connection diagrams, test setups, and real-time power curves with clarity and precision. Bluetooth connectivity enables wireless data transfer to Rigel’s Med-eBase software or the Elite Test and Tag printer, simplifying data management and reporting.
Compliant with IEC 60601-2-2, the Uni-Therm supports performance testing up to 8A RMS and load ranges of 0–5115Ω, ensuring versatility for both conventional and high-power electrosurgical generator calibration. Built-in return electrode monitoring, onboard memory, and automated testing promote efficiency and ensure consistent, accurate results.
The Uni-Therm’s scope output allows waveform verification, and its integrated resistor network ensures safe, streamlined testing from a single, compact device — making it the ideal analyzer for biomedical engineers focused on precision and compliance. (Generated by AI)
FORUMSView All (3)
-Ben C
Wed Aug 05 2020
Rigel Uni-Therm Electrosurgical Analyzer
Uni-Therm is versatile and compact yet offers safer, faster and more accurate testing of electrosurgical generators enabling you to meet international and manufacturer specific test requirements simply and efficiently.Reply
-Ben C
Wed Aug 05 2020
Rigel Medical Uni-Therm - ValleyLab Force FX. PM
This video is a "how to" on accomplishing a preventive maintenance (PM) of a Covidien, ValleyLab, Force FX ESU using the Rigel Medical Uni-Therm analyzer. Automated test sequences includes tests for REM/CQM, HF leakage and ESU power. On screen connection diagrams and pass/fail criteria simply the test process. Test sequences are available for other Covidien e.g., ForceTriad, and ConMed surgical generatorsReply
-SIU2014
Tue Aug 04 2015
ESU analyzer review
Has anyone used this esu analyzer before and if so how did it perform.
Any recommendations for an analyzer would greatly be appreciated.
Thanks
VIDEOS
Rigel Uni-Therm Electrosurgica...
Rigel Medical Uni-Therm - Vall...
  • High current test capability up to 8 Ampere RMS
  • Non-inductive loadbank from 0 - 5115Ω
  • All IEC 60601-2-2 leakage test
  • Onscreen power profile analysis
  • Onboard automation and data capture
  • Full colour user-interface
Height370 mm
Length 300 mm
Power Requirements115 VAC
Weight7 kg
Analyzer/Simulator TypeESU
Width204 mm
