Mindray - Accutorr V
by Mindray
The new Accutorr V vital signs monitor is an easy to use, non-invasive blood pressure monitor with more features and capability. Every unit comes equipped with a recorder, lithium ion battery and your choice of SpO2 technology including Masimo SET®, Nellcor® OxiMax® and DPM SpO2. The Accutorr V is capable of storing up to 1200 measurements easily accessible by patient ID through bar code technology. Plus using the Accutorr CS Charting Solution you can conveniently connect the Accutorr V to your facility’s EMR. If maximum flexibility, high value, and reliability match your vital signs needs, then look no further than the Accutorr V monitoring solution.
FORUMSView All (3)
-Hill452
3 years ago
NIBP Leaking
NIBP Leaking not out side unit, any ideas on what could be the cause.Reply
-Jefrobbo
8 years ago
Calibrating nibp
Any idea of the code to access calibrate nibp
-Rexene
11 years ago
Recording paper
We have a Datascope Accutor monitor SN A7508246K0. What is the reference or order # for the paper to use in this machine?
  • Light weight, portable monitor with large bright LEDs easily read from any vantage point
  • Dedicated buttons for all primary functions promotes ease of use
  • The Accutorr V offers up to 9 hours of run time on one fully charged battery
  • Standard features include NIBP, SpO2, recorder, high resolution LCD display, pulse strength indicator, pulse waveform and a built-in power supply with lithium ion batteries
  • Highly visible alarm light enables instant visualization of alarm conditions
  • Easily configurable settings include patient size, interval time, alarms, inflation pressure, audio levels and temperature formats
  • Quick connect, single hose fittings
  • Unique flexible database stores up to 1200 readings instantly accessible by patient ID
  • With Accutorr CS Charting Solution software, wirelessly link the Accutorr V at the point-of-care to the clinician and to a hospital information system’s EMR
Height25 cm
Length 17 cm
Power Requirements100-240 VAC
Weight3.5 kg
PrinterThermal array
Temperature Range0 to 40 °C
Width17 cm
Display:
Type: Monochrome FSTN LCD
Resolution: 320 x 160 pixels
Pitch: 0.24mm x 0.24mm
Waveforms: Plethysmograph
Parameters: 7 segment LEDs for non-invasive blood pressure (systolic, diastolic, mean),
SpO2, pulse rate, temperature
NIBP:
Measurement Method: Oscillometric
Measurement Modes: Manual, interval, stat
Connector Type: Rectus
Units of Measure: mmHg
Resolution: 1mmHg
Systolic Range: Adult: 55–235mmHg, Pediatric: 55–160mmHg, Neonate: 45–120mmHg
Diastolic Range: Adult: 30–200mmHg, Pediatric: 30–150mmHg, Neonate: 20–100mmHg
Mean Range: Adult: 30–235mmHg, Pediatric: 30–160mmHg, Neonate: 20–120mmHg
Accuracy: Mean error is <±5mmHg. Standard deviation is <8mmHg
Cuff Deflation Technique: Adaptive linear bleed
Cuff Inflation: 200ccs of volume from 0-300mmHg in =10sec
Over Pressure Protection: Double safety protection (hardware and software)
Pulse Rate Range: Adult and pediatric 35–245bpm, Neonatal 70–245bpm
Pulse Rate Accuracy: ±3bpm
Pulse Oximetry
With Masimo SET® SpO2
Measurement Range: 0-100%
Resolution: 1%
Accuracy: ±2% (70–100%, Adult/Pediatric, no motion) ±3% (70–100%, Neonate, no motion) 1-69% unspecified
Pulse Rate With Masimo SET SpO2
Measurement Range: 25–240bpm
Resolution: 1bpm
Accuracy: ±3bpm (no motion), ±5bpm (motion)
With Nellcor® OxiMax® Sp02
Measurement Range: 0–100%
Resolution: 1%
Accuracy: ±2% (70–100%, MAX-A, MAX-AL, MAX-N, MAX-P, MAX-I and MAX-FAST sensors)
±2.5% (70–100%, OxiCliq A, OxiCliq N, OxiCliq P, OxiCliq I sensors)
±3% (70–100%, D-YS, DS-100A, OXI-A/N and OXI-P/I sensors)
±3.5% (70–100%, MAX-R, D-YSE and D-YSPD sensors)
0–69% unspecified
Pulse Rate With Nellcor OxiMax Sp02
Measurement Range: 20–300bpm
Resolution: 1bpm
Accuracy: ±3bpm (20–250bpm), 251–300bpm unspecified
With DPM Sp02
Resolution: 1%
0–69% unspecified
Pulse Rate With DPM Sp02
Measurement Range: 20–254bpm
Resolution: 1bpm
Temperature:
Modes: Monitor, predictive
Measurement Range: Monitor mode: 25°C to 44°C (77°F to 111.2°F)
Predictive mode: 35°C to 43°C (95°F to 109.4°F)
Resolution: 0.1°C
Accuracy: Monitor mode: 25°C to 32°C (77°F to 89.6°F) ±0.2°C (±0.4°F) including 32°C
(89.6°F)
32°C to 44°C (89.6°F to 111.2°F) ±0.1°C (±0.2°F) including 32°C (89.6°F)
Measurement Time: Monitor: <60sec
Predictive: <12sec
