GE HealthCare - Corometrics 118
by GE HealthCare
The Corometrics 118 Fetal Monitor is a twin capable unit that includes one toco and two ultrasound transducers, fetal EKG, event marker and a chart recorder.  Data storage and transmission Integrated Maternal Pulse Oximetry NIBP.  Extends upon the advanced technology of the Model 116 with integrated maternal pulse oximetry and/or noninvasive blood pressure monitoring.
FORUMSView All (18)
-cpalconet
Wed Oct 19 2016
Display
The display for my corometrics 118 has a lines and dot in its display. does it have a reset button or how do I go around this problem?
-Tim528
Tue Sep 27 2016
CMOS Battery
need to know replacement battery number and size
-J Petranek
Fri Jun 26 2015
manual
need one
[list]         [*]Easy operation         [*]Intuitive controls and menus         [*]Simplified operation of all functions         [*]Controls are tailored for labor and delivery to make operation user friendly         [*]Visual/Audible Maternal Alarms         [*]The unit provides visual and audible alarms when maternal SpO2, NIBP or pulse rate values exceed user-defined high/low limits         [*]Audible alarms can be disabled         [*]Individual audio/visual alarms can be temporarily cancelled         [/list]
Direct ECG                  [list]         [*]Technique:  peak detecting beat-to-beat cardiotachometer.          [*]Heart rate counting range: 30-240 BPM.          [*]Heart rate resolution: ±1 BPM.          [*]Artifact elimination:  switch selectable ±25 BPM artifact rejection.          [*]Input signal range differential:  15 µV to 2 mV peak-to-peak (fetal), 100 µV to 2 mV peak-to-peak (maternal).          [*]Common mode: 20 VDC (max.).          [*]Preamplifier bandwidth: 1.0 Hz to 100 Hz.          [*]Common mode rejection: >120 dB balance.                    With patient cable: >110 dB 5k RA or LA unbalance.          [*]Input equivalent noise: 10 MΩ, common mode > 20 MΩ.         [*]Main frequency rejection: >40 dB.          [*]Leakage current:  2kV.          [*]Leg plate tester: simulated r-wave at 120 ±1 BPM.         [/list]         [/quote][quote]Ultrasound[/quote][quote]         [list]         [*]Technique:  pulsed doppler with autocorrelation processing.         [*]Pulse repetition frequency:  4kHz in single ultrasound mode, 2 kHz in dual ultrasound mode.         [*]Pulse duration:  92µs.         [*]Center frequency:  1.151 MHz         [*]Intensity:  <10 mW/cm2         [*]Heart rate counting range:  50-210 BPM.         [*]Leakage current: <10 µA at 120 VAC.         [/list]         [/quote][quote]Pressure[/quote][quote]         [list]         [*]Range: 0-100 mmHg         [*]Tocotransducer: 0-100 relative units (0-120 grams)         [*]Excitation voltage:  +4.0 VDC         [*]Resolution: 1 mmHg         [*]Bandwidth: tocotransducer DC to 0.5 Hz, strain gauge DC to 3 Hz         [*]Zero temperature drift: < 0.1 mmHg/°C (electronics only).         [*]Leakage current:  <10 µA at 120 VAC (transducer isolated).         [/list]         [/quote][quote]Recorder[/quote][quote]         [list]         [*]Uterine activity: chart width: 4 cm, scaling: 25 mmHg/cm (3.33 kPa/cm), range: 0-100 mmHg, resolution: 1 mmHg.          [*]Chart drive: speeds: 1, 2 and 3 cm/min; accuracy: ±1%.         [*]Heart rate scale: domestic - chart width 7 cm, scaling 30 BPM/cm, range 30-240 BPM, resolution 1 BPM; international: chart width 8 cm, scaling 20 BPM/cm, range 50-210 BPM, resolution 1 BPM         [/list]         [/quote][quote]Power Requirements[/quote][quote]         [list]         [*]Voltage: 100/120/220/240 VAC selectable         [*]Frequency: 50/60 Hz.         [*]Power consumption:  100 Watts (max)         [/list]         [/quote][quote]Physical Characteristics[/quote][quote]         [list]         [*]7" H x 16.5" W x 17" D (17.8 x 41.9 x 43.2 cm)         [*]Weight:  approximately 34 lbs (15.5 kg)          [/list]
