Allied Healthcare Products - Schuco-Vac 130
The Schuco-Vac 130 Aspirator has bacteria and hydrophobic filters that prevent fluids and other contaminants from damaging the pump.The Schuco-Vac® 130 aspirator is ideal for any small office, clinic, hospital or wherever portable suction is required. This durable unit provides controlled vacuum regulation from 0” up to 22” Hg with a flow rate of 28L/min. Bacteria and hydrophobic filters help prevent fluids and other contaminants from damaging the pump. The wire basket accommodates a variety of canisters. Also features a vibration-free, easy-to-read regulator gauge and convenient quick-connect tubing. With 800cc canister.
SERVICE COMPANIESView All Aspirator Companies
[list] [*] Vibration-free easy-to-read regulator gauge [*] Wire basket accommodates a variety of canisters [*] Quick-connect tubing for all connections [*] Hydrophobic/bacteria filter eliminates pump flooding, and prevents contaminant damage [*] 3 filters included with every pump [/list]
Height | 11 in |
Length | 13.8 in |
Width | 8 in |
Flow rate - 28L/min. Air flow at 0” Hg- 36.8L/min. Usage rating- Continuous Sound level- 60 dba (from 1m) Vacuum pump type - Oil-less diaphragm Max vacuum - 560mm Hg @ sea level Motor type- AC Power requirements- 115VAC, 60 Hz
