Allied Healthcare Products - Gomco Portable
Delivery of high-performance suction at any timeHighly versatile and compact, they can be used in multiple clinical settings, from the emergency room to the recovery room. A carbon rotary vane design makes them low-maintenance. The self-contained aspirators protect against contamination of motor and gauge to allow for easy cleanup. The high vacuum and flow provide immediate high-performance suction, having an output range of 0” to 25” Hg vacuum and a liter flow rate of 30L/min.
4Replies12 years ago | Allied Gomco 400 Looking for the manual for an Allied Gomco Aspirator model 400. Franks does not have it, anyone else? Reply |
SERVICE COMPANIESView All Aspirator Companies
Height | 12 in |
Length | 9 in |
Weight | 14.5 lbs |
Width | 12 in |
Vacuum range- 0” to 25” Hg/min. at 115V Flow rate - 0 to 30L/min. at 115V Electrical requirements- 115V, 60 Hz Fuses - 3A slow blow fuse
