Fluke Biomedical - QED 6
by Fluke Biomedical
The QED 6 Defibrillator Analyzer delivers a scalable and precise solution for testing defibrillator performance, making it ideal for biomedical engineers and clinical technicians. Designed for ease of use in both field and lab environments, the QED 6 is lightweight, portable, and capable of accurately measuring a wide range of defibrillator energy output parameters, including energy delivery, charge time, and waveform analysis. Whether you're performing routine maintenance, compliance checks, or emergency equipment validation, the QED 6 ensures reliable and repeatable defibrillator performance testing. (Generated by AI)
1ReplyThu Mar 20 2014 | QED6 Defibrillator Analyser I would like to test my Automated External Defibrillator(AED) using QED6 defibrillator analyser and connected the Apex and sternum terminals of AED to QED6. My SW is somehow reading incorrect patient impedance say 200ohms instead of 50ohms standard load provided by QED6. In that case if energy,say 360J(360J is the maximum energy that can be supported by our AED)is delivered by AED to QED-6, will there be any chance that the QED-6 gets damaged? Please clarify. Reply |
[list] [*] Monophasic and biphasic dc energy measurement [*] Energy and cardioversion measurement [*] Peak voltage, peak current, and overshoot measurement [*] 2-line x 24-character display [*] Bidirectional RS-232 port for computer control [*] Storage and playback of output waveform so results can be viewed in greater detail [/list]
| Height | 4 in |
| Length | 10.5 in |
| Weight | 4.54 lbs |
| Analyzer/Simulator Type | Defibrillator |
| Current Range | 35 to 110 A |
| Voltage Range | 20 to 5500 V |
| Width | 9.5 in |
