Fluke Biomedical - SigmaPace 1000
by Fluke Biomedical
The SigmaPaceTM 1000 is a powerful handheld tool with a comprehensive range of test suites, measurement algorithms and test loads – as specified by the external pacemaker manufacturers – to fulfill your testing requirements both quickly and efficiently.
1ReplyWed Feb 17 2021 | PM procedure Is there a checkout procedure using the SigmaPace 1000Reply |
0RepliesSat Jun 23 2018 | SigmaPace" 1000 External Pacemaker Analyzer The SigmaPace" 1000 is a powerful handheld tool with a comprehensive range of test suites, measurement algorithms and test loads as specified by the external pacemaker manufacturers to fulfill your testing requirements both quickly and efficiently.Reply |
[list] [*] Unique full-featured biomedical test product [*] Tests for both transcutaneous and transvenous external pacemakers [*] Full range of user-selectable measurement algorithms and test loads for external pacemakers [*] Dual-channel signal acquisition for capturing synchronous AV-sequential pulse data [*] Interactive pacemaker and ECG simulation with 5-lead output [*] Large 21-character x 8-line alphanumeric LCD readout [*] Exclusive readout "HOLD" function [*] Exclusive SigmaPaceTM 1000 test features: DC static/dynamic leakage, and current drain [/list]
| Height | 50 mm |
| Length | 203 mm |
| Weight | 0.9 kg |
| Analyzer/Simulator Type | Pacemaker |
| Width | 101 mm |
Power Requirements:: External battery charger source/power supply 100 to 240 Vac, 50/60 Hz operation. Auto power-off feature during battery operation. Battery Life: 20 hours (min)
