Fluke Biomedical - DALE 601E
by Fluke Biomedical
The DALE601E Electrical Safety Analyzer is a trusted tool for biomedical engineers, offering an extensive range of electrical safety and performance measurements for medical equipment. Its intuitive single master function switch guides users step-by-step through complex testing procedures, ensuring efficient and accurate diagnostics.
The DALE601E accurately measures line voltage, instrument current, ground resistance, earth and chassis leakage, patient lead-to-ground, lead-to-lead isolation, M.A.P. current, external gradient, and transducer isolation current, among others. Designed for precision, it incorporates a four-wire Kelvin bridge to eliminate resistance reading errors due to cable length and contact resistance.
Featuring true RMS current readings, a selectable AAMI or IEC test load, and five universal EKG lead connectors, this analyzer supports virtually all lead types in clinical and laboratory settings. Heavy-duty switches simplify polarity changes, neutral opens/closes, and leakage current test selection. (Generated by AI)
3RepliesSat Jul 13 2013 | used dale 601e anyone know where I can find a decent priced Dale 601e. Fluke wants just way too much for this item.
Thanks, Nick Putch Reply |
2RepliesTue Apr 30 2013 | Fluke does not pass calibration testing I have a question concerning a dale 601e meter we sent in for calibration testing at a calibration facility : The test facility measured a high resistance between earth gnd. of AC inlet and output test receptacle of 34 kOhm. Does that measurement have a specification. I did not find one in the manual. Thanks Jack
Reply |
[list] [*] Small, lightweight, self-contained portable instrument [*] Master range meter delivers accurate measurement for each test [*] Accurate test measurements with 4-wire Kelvin bridge [*] Leakage Current can be measured in Open/Closed Neutral, Normal/Reversed Polarity and Open/Closed Ground [*] All Leakage Current measurements are displayed directly in µAmps [*] Broad range of external measurements [*] Five (5) Universal EKG Lead Connectors [*] The DALE601E is designed for 230 V operation [/list]
| Height | 196 mm |
| Length | 41 mm |
| Analyzer/Simulator Type | Electrical Safety |
| Current Range | 0 to 10 A |
| Width | 102 mm |
