Fluke Biomedical - VT Mobile
by Fluke Biomedical
The VT MOBILE Gas Flow Analyzer is a compact, portable, and versatile testing tool designed specifically for biomedical engineers and field service technicians. Ideal for evaluating the performance of a wide range of medical gas-flow and pressure devices, the VT MOBILE supports compliance with EC.6.20, which requires 100% completion of life-support device preventive maintenance annually. (Generated by AI)
Measures 16 critical ventilator parameters including flow, volume, pressure, and oxygen concentration
Supports high- and low-flow ranges for broad application coverage
Built-in waveform display via onboard graphing for real-time, on-screen analysis
Stores test results internally, with easy upload to PC via VT for Windows software
Simultaneous display of all parameters speeds up ventilator performance evaluations
Compatible with ACCU LUNG precision test lungs and other test lung accessories (sold separately)
Optional temperature and humidity module for increased measurement accuracy
Lightweight, rugged design – ideal for mobile use in hospitals, clinics, and service calls
(Generated by AI)
| Height | 1.5 in |
| Length | 8 in |
| Weight | 1 lbs |
| Analyzer/Simulator Type | Gas Flow |
| Width | 4 in |
