GE HealthCare - AMX 4 Plus
by GE HealthCare
When you need to get to a patient fast, you need a durable, mobile X-ray imaging system. GE Healthcare’s AMX-4+ analog X-ray system answers that challenge by providing high-performance in a compact, easy-to-maneuver package. The rotating arm and tube simplify positioning and facilitate bedside studies, while the maintenance-free battery produces up to 50 high-quality exposures with a single charge.
1ReplyFri May 22 2026 | AMX 4 Plus shows fully charged but still fails test 4 I bypassed checksum and got machine to fully charge ( or it shows fully charged on bar), but still failing test four, do I need to calibrate charger or voltage again ? Reply |
1ReplyMon Nov 24 2025 | Changing battery Can you put me through on how to connect amx 4 battery Equipment: Amx 4 x ray machine Reply |
3RepliesTue Jul 29 2025 | GE Amx 4 doesn't boot ip Hi everyone Please I have this Amx 4 X-ray machine by GE. At switch on the display board has a non recognizable characters displayed and the machine does not boot up, each time the RESET button is pressed, nothing happens. Does anyone has some clues to solving this problem. Thank you Reply |
[list] [*]Dual drive motors and oversize casters facilitate movement; even in taxing environments. [*]Ease of use, effortless maneuverability and 270 degree column rotation add positioning flexibility across diverse care areas and exams, even in tight spaces. [*]Large installed base results in operator familiarity, reducing training costs. [/list]
| Maximum Focal Spot | 0.75 mm |
| Height | 70 in |
| Length | 45 in |
| Weight | 1080 lbs |
| Width | 25 in |
Remote x-ray control: Handswitch-Standard
