Fluke Biomedical - PS420
by Fluke Biomedical
The PS420 is a handheld, high-performance device for testing patient monitors.
The PS420 Patient Simulator is a highly portable, pocket-sized solution designed for biomedical engineers and healthcare technology management (HTM) professionals who require accurate and versatile testing of patient monitoring systems in the field or clinical setting. Despite its compact size, the PS420 delivers full-feature simulation of key physiological parameters for routine inspection and troubleshooting. (Generated by AI)
-mimi
Thu Apr 25 2013
Respiration
what are the cable connections in order to record respiration
e.g. RA, LL
  • 12-Lead ECG Simulation: Accurately simulates full 12-lead ECG signals for comprehensive cardiac monitor testing.
  • Dual-Channel Blood Pressure Simulation: Provides two independent channels for realistic invasive blood pressure (IBP) signal testing.
  • Extensive Arrhythmia Library: Includes 35 commonly encountered cardiac arrhythmias to verify monitor alarm response and waveform recognition.
  • Pacemaker Function Support: Simulates pacemaker pulses for testing pacemaker-detection features in modern patient monitors.
  • Adult and Pediatric Sinus Rhythms: Supports simulation of normal sinus rhythms for both adult and pediatric profiles, enhancing versatility across clinical applications.
  • Field-Test Ready: Lightweight and battery-operated, the PS420 fits easily in your pocket, making it ideal for on-the-go biomedical equipment maintenance. (Generated by AI)
Height1.3 in
Length 6.1 in
Weight0.9 lbs
Analyzer/Simulator TypePatient Simulator
Width3.7 in
Housing: ABS plastic case        Display: 2-line by 16-character LCD with keypad        RS-232: Bidirectional interface, 9600 Baud
