Fluke Biomedical - BP Pump 2
by Fluke Biomedical
Non-Invasive Blood Pressure Simulator and Tester
The BP Pump 2 provides dynamic blood-pressure simulations for testing adult and neonatal noninvasive BP monitors, including both arm- and wrist-cuff types. The analyzer features a preset mode for simulation of most patient conditions and the capability to program user-defined simulations. BP Pump 2 tests for leaks, measures static pressure, generates pressure, and tests overpressure valves. For improved testing versatility, the analyzer’s recently upgraded waveform test suite includes additional physiological selections. BP Pump 2 comes in two models: the standard BP Pump 2L and the BP Pump 2M, which features a high-accuracy pressure transducer. BP Pump 2 also includes an optional five-lead ECG test capability.
-Ehsan
13 years ago
Proper Usage
want A user manual
[list]        [*] Dynamic simulations for arm- and wrist-cuff monitors        [*] Physiological waveform        [*] Internal pump for use in high- and low-pressure release verification, leak testing and pressure sourcing        [*] Preset mode for simulation of most patient conditions        [*] User-definable systolic and diastolic values, along with heart rate and pulse volume and user-defined autosequences        [*] Internal cuff volume for basic device testing         [*] Respiratory artifacts, including spontaneous breathing and controlled ventilation        [*] Arrhythmia simulations, including premature atrial contractions #1 and #2, atrial fibrillation, and PVCs        [*] PC based ansur test automation system to standardize testing protocol and documentation (optional)        [*] High-accuracy pressure transducer (BP Pump2M only)        [*] Dynamic pressure repeatability within 2 mmHg at maximal pulse size independent of device under test        [/list]
Height5 in
Length 10 in
Weight7.5 lbs
Analyzer/Simulator TypeNIBP
Width10 in
