Hitachi Medical Systems - HI Vision 5500
The HI VISION 5500 Fully Digital Ultrasound system delivers the latest generation of signal processing technology.The HI VISION 5500’s electronic architecture incorporates advanced circuit designs optimized for efficiency and function. The HI VUE – an engineering philosophy that directs the development of each subsystem to individual specifications while, at the same time, providing seamless integration within the entire system. The end result is extraordinary performance in image quality and system operation. Every aspect of the 5500’s operation was engineered to make it a better clinical partner in real-life, real work situations. Hitachi’s dynamically backlit control panel uses three-stage illumination to give visual feedback on system operation. Keyboard lighting shows each function as available, unavailable, or in use. In addition, programmable one-touch keys increase system efficiency by providing individual controls for frequently used image acquisition, processing, storage, and retrieval functions.
FORUMSView All (11)
1Replya year ago | setting system data please wait" How can i resolve thus please sirs. Can enybody send compress copy of the system cd to me please. Equipment: Hitachi 5500 " Reply |
2Replies5 years ago | DBF Ram Failure So when I do the RAM test in the service options all of the ram passes except the "Transmission RAM" on the DBF board. I am trying to figure out what issues might cause this ram to fail the test. I am not even certain which RAM this is. I have attempted replacement of all the PC133 128MB RAM sticks with no impact. I have not yet purchased a probe because I don't want to if this system can't be fixed however could not having a probe impact the test? Can anyone tell me which RAM specifically it is referring to or what factors may cause it's failure?Reply |
1Reply5 years ago | Transducer Compatibility Are there any other transducers that are compatible with this machine? I've been asked this question and as far as I know you have to use a transducer with the Hitachi connector. Thanks YouReply |
Ease of Use
- Tri-color keyboard lighting for intuitive operation
- One Touch Access to Commonly Used Functions
- User Defined Programmable Keys
- Durable, Lightweight, and Highly Mobile
Advanced Performance
- Quadra Beam Processing for Fast Frame Rates
- 12 bit Gigasampling A/D for Precise Signal Reproduction
- Windows XP based for reliability, stability, and familiarity
- HI VUE circuitry for streamlined operation and signal flow
- 3 Modes of dynamic Tissue Harmonic Imaging (dTHI)
- Directional Color Flow Angiography
- Real-time Doppler Measurements
Standard Features
- Patient and Image Database Management System
- Enhanced Cine and M-mode recording with Cine-max memory
- 3RD Generation Color Artifact Suppression
- Powerful Built-in Measurement and Equation Editor
- Customizable Presets and Preset-Operation Functions
Optional Imaging Enhancements
- WideView Panoramic Imaging Option
- 3D Imaging Options (built-in or stand-alone)
- Single Omni-directional M-Mode Display Option
- Steerable CW Doppler Option
- ECG Biophysical Display Option
- Pentax EUS and Fujinon Mini-probe Options
Cart Based | 1 |
Height | 55 in |
Length | 31 in |
Weight | 286 lbs |
Clinical Applications | Colorectal |
Imaging Capabilities | 2D/3D |
Color-flow Mapping | 1 |
Doppler Modes | Color, Continuous wave (CW), Pulsed wave (PW), Color flow angiography |
Image Display | 15 in Color CRT |
Width | 20 in |
