Philips - Brilliance 64
by Philips
The Philips Brilliance CT 64-slice is one of the most advanced CT systems in the market. This system can expand clinical boundaries in cardiac, pulmonary, trauma, and pediatric imaging. This system is built on innovative Essence technology that delivers image quality, dose efficiency and rapid reconstruction times. The Brilliance CT 64 channel configuration package embodies completely the philosophies of sense and simplicity applied to more effective patient care. With a range of new and targeted advancements, including low-dose cardiac imaging, 3D volume software and expanded portal capabilities, this system takes the raw capabilities of volume imaging and makes them work harder for patients by making the physician’s work easier. This is the system for those who want the latest CT can offer, and realize productivity is an integral component of results.
0Replies2 years ago | Purchase I need to buy pre owned 64 slice CT and get it installed . Contact me here or baats2000@gmail.com or banjimx2@yahoo.com Reply |
3Replies3 years ago | Resource allaocation failure System - Philips Brilliance 64. I have a scanner that will zero ok, but any attempt of any scan (including tube conditioning), throws up an error 'Resource Allocation Failure'. A look in the Event Viewer for server 1 in the CIRS shows an error 'Get Ready Failed'. I cant seem to find any reference for this fault. I have been able to 'Slave in' a spare Server 1, but I still get the same issue and errors. Im beginning to wonder if the Host should send a Get Ready signal, but isnt. Can anyone tell me where this fault originates please. Reply |
6Replies5 years ago | COUCH´S VERTICAL MOVEMENT FAULT The system won´t move the couch in the vertical direction. If I press the buttom switch on the gantry, the leds goes off for a while, but the couch doesn´t move. However, when I select the service switch, the couch can be move up and down. I already try to flash the CPM, check interlocks and voltages.Reply |
Type (configuration) | Multislice |
Maximum Scan Range | 175 cm |
Gantry (Max. Clearance) | 70 cm |
Patient Weight Capacity | 450 lbs |
