GE HealthCare - Marquette MAC 5500
by GE HealthCare
GE's premier ECG system
Built on GE's proven innovation in EKG / ECG acquisition and analysis, the MAC® 5500 delivers advanced disease management capabilities through its industry-leading collection of standards-setting algorithms and advanced networking.
The MAC 5500 system offers the sophistication required for advanced ECG applications, while its ease of use extends this level of performance to the broadest range of users possible. And, it's part of the complete GE suite of networked, non-invasive testing solutions designed to maximize efficiency and productivity in hospitals, clinics, office-based practices, and research institutes.
FORUMSView All (54)
-AlexKhun
Wed Oct 29 2025
Bar code scanner not working
Hi all,
When pressing the F1 key to select "patient data" on the MAC 5500, there is this quick flash to scan the patient visit/ID number to add them to the ekg cart, then it switches to manual entry right away. Kept pressing that F1 button to use the scan function, but it will switch to manual entry.
What's causing the issue? Software upgrade? Internal board malfunctioning? Settings?
I've double checked the settings to another working ekg and all settings matched. Problem still there. Tried hard reboot of device. Nothing. Replaced the scanner and cable to a known working one. Same issue.
Can't get in contact with GE tech support. Anyone has had this problem?
-Lalalalsld
Tue Jul 08 2025
Printing maybe
Error when printeing why
-diego7
Fri Jul 04 2025
Where do you go to find steps to troubleshoot it
verygoodo ha nevermind
  • 12-/15-Lead High-End ECG System for Resting-ECG's and Stress-Test
  • Easy-to-use applications and features streamline productivity and workflow
  • Advanced algorithms set the standard in ECG analysis and interpretation
  • Improving Clinical Trial Workflow with CT Data Guard
  • Multiple Network Capabilities (Ethernet and wireless)
  • Internal Modem
  • Barcode and magnetic card scanning options
  • XML data export capabilities
  • Internal Memory for 200 ECG's, SD-card removable Media
  • Seamless connectivity to the MUSE® cardiology information system speeds data storage and ECG retrieval
EKG/ECG TypeRest
Height3.37 in
Length 13.8 in
Weight15 lbs
Width15 in
