Burdick - Quest
by Burdick
Burdick Quest cardiac stress testing system
The Quest system is right for offices looking for value, simplicity, and increased patient throughput. The system is easy to use because it features a touch screen with convenient pull-down menus for intuitive workflow. Our proprietary Logistep guide walks users through the test by highlighting the next step. We put everything you need on one screen, so there's no need for toggling among screens. And to save you time, we added an easy way to correct unintentional phase changes without having to start all over again.
FORUMSView All (20)
-mesee
14 days ago
System is stuck at Quest - "starting up" at 100%.
System is stuck at Quest - "starting up" at 100%. Is there anything we can do to resolve this issue. We restarted the system few times, used to work in the past, no longer does. Thank you, MelReply
-MMoss
a year ago
Password Reset
We acquired our exercise stress system from another office and have no access to the usernames/passwords. Is there a way to over-ride these credentials to create new ones? Reply
2
-Michael242
a year ago
hard drive too full
How do I clear the whole drive, 1800 studies, all at once ?Reply
  • Eleven standard, preprogrammed protocols
  • Performs both resting 12-lead ECGs and stress tests
  • Touch screen interface
  • Logistep software guides testing, step by step
  • Option to use the University of Glasgow ECG interpretation algorithm
  • Compatible with Ethernet protocols, our Pyramis data management system, and our HeartCentrix connectivity solution
  • Warranty: 3-Year Parts and 1-Year Labor
EKG/ECG TypeStress
Image Display15 in High-resolution color with integrated touchscreen
Weight170 lbs
