AGFA - ADC Solo
by AGFA
AGFA ADC Solo CR Digitizer - CR System is the smallest-footprint, fully functional digitizer on the market today. It features a unique identification function, which receives patient data while the imaging plate is being scanned, avoiding the need for a separate ID Tablet and additional cassette handling.
0RepliesMon Jul 25 2022 | Agfa ADC Solo Software Hello, We have bought a Agfa Solo without licence. I have found an ADC Compact ID Software. I installed it on the computer with the Id and preview licence. But when I click on the Agfa prid application, I have an error message "the item jrew.exe that this shortcut refers to has been changed or moved, so this shortcut will no longer properly" i moved this file in the java\bin file but the agfa software still not working. Can you help me? Thank you SarahReply |
5RepliesFri Nov 27 2020 | AGFA Digitizer, ADC SOLO. When the cassette is inserted, appears the message "EMPTY CASSETTE" Hi all We have an AGFA Digitizer, ADC SOLO. When the cassette is inserted, appears the message "EMPTY CASSETTE". When the cassette comes out, it was not opened. Could someone give us a suggestion? Could someone send us the service manual? Reply |
0RepliesSun Nov 03 2019 | Error codes 21012 Hello there I have model Agfa Adc solo Cr 5155/100 device. as error code : 21012. (Reason:cannot create control file. Creation of the file containing the control data failed. ) I checked the HDD there was a bad sector I found a solid hdd I made one to one copy I did hdd repair through the system Again gives the same error Do you know anything about this topic Thanks |
| Height | 56 in |
| Length | 30 in |
| Weight | 463 lbs |
| CR-System Configuration | Single-plate floor unit |
| Width | 18 in |
