AGFA - CR-25
Small footprint digitizer for a unique range of clinical applications CRThe small AGFA CR 25.0 footprint allows it to be placed easily at any location. Designed with ease of use in mind, it requires only a standard wall-outlet. Broad range of applications: The AGFA CR25 is a highly versatile CR Unit. It offers an ideal solution for any decentralized Computed Radiography environment. AGFA CR 25 can handle General Radiology, Orthopedics, Dental and Pediatric applications. The AGFA CR25 CR System is also a perfect complement to existing centralized CR systems. Full data The CR 25.0 reads imaging plates at a standard resolution of 6 pixels/mm. 10 pixels/mm high resolution capability is available for all image plate sizes. 20 pixels/mm resolution will be available for dedicated 18 x 24 cm and 24 x 30 cm mammography and extremities cassettes and plates.
FORUMSView All (20)
0Replies2 years ago | Nx Licence I lost the key NX licence to operate my CR is it possible to get one? Equipment: AGFA - CR-25 Reply |
1Reply5 years ago | No permission to start the application. Ref. MESS89 This is the message I recieved when opening the NX WIBU key is ok license is ok Windows user is ok (Crservice) Reply |
1Reply5 years ago | help needed on CR 85-X Type 5148/100 Error : 24AB0 & 20E0EReply |
Height | 55.5 in |
Length | 29.5 in |
CR-System Configuration | Single-plate floor unit |
Mammography Support | 1 |
Width | 17.7 in |
