AGFA - ADC Compact Plus
by AGFA
Maximizing Throughput and Staff Productivity as You Begin the Transition From Analog to Digital
Optimal Productivity and Ease-of-use The ADC Compact Plus digitizer accommodates multiple users and features a drop-and-go buffer that eliminates waiting times; all the user has to do is to deposit cassettes. The ADC Compact Plus digitizer automatically takes the cassettes from the input buffer, reads the demographic data from the memory on the cassette, scans the imaging plate, digitizes the image and returns the cassette to the output buffer for new exposures. No Waiting The input/output buffer system of the ADC Compact Plus digitizer takes up to ten cassettes at a time. A user can immediately deposit cassettes and return to the patient. Waiting times at the digitizer are eliminated and staff productivity is maximized. Compact Footprint The ADC Compact Plus digitizer occupies a very small floorspace and allows two users unhindered access, one at the input and one at the output, resulting in a smooth flow of operations. It is ergonomically designed to ensure an efficient and safe workplace. High Productivity The cassette buffers virtually eliminate waiting times for the staff and bring the average throughput of the system close to maximum: when cassettes are in the input buffer, the system operates automatically at maximum speed, without idle times. No-button/no-switch operation with automated cassette handling makes the ADC Compact Plus digitizer a highly productive and user-friendly system, with a throughput of 90–100 plates an hour depending on size.
FORUMSView All (10)
-Valyvet
4 years ago
Error 2259B
Hi. Got a new error code 2259B. What could it be?Reply
4
-Valyvet
5 years ago
Self test failed
CR doesn't complete self test. Error service 2249FReply
3
-Onyeka
5 years ago
ADC COMPACT PLUS
Please i need help... My ADC COMPACT PLUS is not accepting Agfa general cassettes. Any suggestions Reply
[list]  [*] Automated CR plate reading with no manual interaction necessary  [*] Waiting times are virtually eliminated;users simply deposit cassettes  [*] Maintains equity of current equipment investment while charting a path to digital  [*] Simple operation and automated cassette handling processes up to 100 plates per hour  [/list]
Height56 in
Length 45 in
Weight705 lbs
CR-System ConfigurationMulti-plate floor unit
Width33 in
