iCRco - iCRVET
Veterinary CR SystemThe iCRVet is a Computed Radiography (CR) machine designed to meet all the needs of Veterinarian Professionals. Paired with the windows based QPC XSCAN32 Veterinary Software which can be customized to your needs. This machine is by far the easiest CR System to operate. The iCRVet's patented design incorporates a True Flat Scan Path™, an ultra precise scan mechanism and protective cassettes to produce over 300,000 high resolution images per plate.
iCRco imaging plates are fixed to a rigid back panel. Nothing ever touches the active area of the phosphor plate resulting in an artifact free image. Unlike most CR products, the iCRVet uses no rollers to transport the plate across the scan head. A positive traction drive system ensures perfect artifact free reproduction.
The iCRVets small footprint and the optional wall-mount makes it a perfect fit for small spaces or installation inside the X-Ray room for maximum productivity.
Weight | 78 lbs |
CR-System Configuration | Single-plate table unit |
