Viztek - Opal CR System
by Viztek
Viztek Opal-CR is the fast and easy way to convert your facility to digital today! The easy-to-use tabletop CR can produce 56 plates per hour while offering crisp image quality. Reading images at 10 pixels/mm, the compact CR can be used in any environment, including mobile units. Viztek Opal-CR is the fastest way to take existing analog imaging into the digital realm. Additionally, the CR also offers significant speed and image quality over analog film processing. Moving into the digital x-ray world is simple: retain your current x-ray machine and add the Opal-RAD Acquire Workstation and a CR digital scanner. These tools provide a truly stand-alone acquire workstation where images are acquired, quality checked, diagnosed, archived, and optionally sent to an external PACS. This is an optimal solution for small clinics looking to leave their film processing days and reduce the cost of radiology.
Used in combination with an Opal-RAD PACS, the Opal Workstation becomes an invaluable member of the Viztek suite of digital radiology software tools. X-ray technologists are able to continue scanning new patients while the images are stored on the central Opal-RAD Server and doctors view the exams in Patient rooms on connected Opal-RAD Viewers.
As a standalone product or part of a larger PACS, the Opal-CR is your solution for taking your current x-ray business into the digital realm.
1Reply3 days ago | Cassette Compatibility Hello all, Can the Viztek Opal-CR use other types of CRMD 4.0 subtypes? ours came with the CRMD general 4.0'T' and we have only replaced it with the 4.0T. CanViztek Opal-CR use other types like the 4.0 or 4.0R? I will dive into the manual that I was able to recover, but thought I would ask you pros! Thank you. -AndrewReply |
1Reply2 years ago | How do I reinstall and configure the OpalStudylist and associated tools correctly? I had a crash of my hard disk and I have to reinstall the Opal Studylist and associtaed tools. I have a backup of the installer files and the licence file. How do I go about installing the files, setting up the database and logging in? Thanks.Reply |
1Reply8 years ago | Not all images are transfering My client is a chiropractor and he uses Opal. Often, but not always, the system does not transfer all the images to the server. If he takes 4 shots, only 3 will make it (but it isn't always the last image?). Has anyone else had this issue? How did you fix it? Reply |
CR-System Configuration | Single-plate table unit |
