STERIS - AMSCO GEMINI
by STERIS
Amsco Gemini Surgical Light allows full range of mechanical and optical flexibility required for surgery. Ideal for minor surgical procedures.
The mobile stand floor unit is easily moved on any type of floor surface.    Perfect blend of excellent optical performance, smooth maneuverability and drift-free stability.    Easy, touch switch operation. A choice of large and small pattern sizes tailors the light spot to the size of surgical incision, and three lamp intensity levels are available to assure the proper amount of glare free lightning.    Homogenous, well-defined lightning with no hot spots and excellent shadow control.
FORUMSView All (7)
-Kparker48
11 years ago
amsco gemini
How do i make the light swivel from left to right it seems like everytime i tr to make that motion its to tight, but wen i move the handle on the light ro make it move up and down it moves real easily?
-engrjed
13 years ago
Surgical Light
too much heat on the lighthead assembly.
-rdttech
13 years ago
Bad socket
Looking for a replacement socket, even a part number.
Any help would be nice.
[list]  [*] Mobile stand easily moved on any type of floor surface.  [*] Drift free stability.  [*] Excellent optical performance.  [*] Easy touch switch operation.  [*] Color temp. 4200 k.  [*] Voltage requirements 100/120/220/240 volts 50/60hz.  [*] Lamp voltage 200w.  [*] Three lamp intensity levels.  [*] Glare free lighting with excellent shadow control.  [/list]
Color Temperature4200 K
Lighthead Diameter22 in
