Megadyne - Mega Power
by Megadyne
[b]The future of electrosurgery (diathermy) is here today[/b] The intuitive design and user-friendly set-up of the Mega Power Electrosurgical Generator (diathermy) allows your surgical team to hit the ground running. The confusion and frustration associated with previous generators are a thing of the past. Surgical teams have been asking for a generator that is simple, intuitive to use, and easy to set-up. The Mega Power is the answer with simple but elegant features that include: [list] [*] Large, easy to read displays. Highly visible, even at a distance. [*] Recall feature readily recalls previous power settings and modes on set-up. [*] Quick scroll feature allows for fast and accurate power setting adjustments. [*] Power switch is easily accessible on front panel of generator. [*] Highly visible return electrode warning light. [*] 6 clearly labeled and easily selectable mode settings. [/list]
1ReplySun Mar 03 2024 | Need service manual Bipolar energy is not out continue Equipment: Megadyne - Mega Power Reply |
3RepliesSat May 13 2023 | Calibration Can anyone provide the calibration needs and procedure for the Megadyne Mega Power 1000? Thank you Reply |
1ReplyMon Dec 05 2022 | patient return fault found R186 burnt open . value stamp rendered undecipherable. any one know the resistance ? i assume it to be a low value 'fused' resistor. still seeking a schematic (which would have this info )Reply |
