Viztek - Opal CR II
DIgital Detector
Viztek's Opal CR II is the ideal solution for converting x-ray to digital. The CR is scalable and has a sleek footprint that is easy to install virtually anywhere. Weighing only 65lbs, the CR II can easily be used in applications where space is limited. An optional vertical wall mount is available, offering multiple installation options. Viztek CR II offers an easy in field upgrade to go from 20 plates per hour to 73 plates per hour, as your facility volume grows. Viztek CR II is supported by Symphony III post processing software complete with enhanced grid suppression. Vizteks Opal Acquire software is also expandable with Opal PACS.
- Opal-Acquire viewing software
- Up to 73 plates per hour (14x17)
- Extremely light at 65lbs
- Mounts horizontally or vertically (optional wall mount)
- 14x17 and 10x12 plate sizes
Dimension : 4.6”x18.3”x27.7” (117x464x703mm)
Power Requirement : 110/220/240V, 60/50cs, 150W
10 pixels/mm at 73 pph(100um scanning mode) 10x12
