AGFA - DRYSTAR 5300
by AGFA
The DRYSTAR 5300 is a tabletop imager that makes it the ideal choice for decentralized imaging even in the most space restrictive environment. Direct Thermal technology avoids complex use of optics and makes the DRYSTAR 5300 more durable by design. No need for darkrooms or special packaging for the media. This makes the loading of media easy in any lighting condition. [list] [*] Direct Digital Imaging technology [*] A decentralized hardcopy solution [*] Easy daylight loading [/list]
1ReplyMon Jun 16 2025 | Self test failure error During self test at about 84%, the "self test failure" message is show on display. Reading infocounter, the last error, one month old is HC204002, but nothing about actual state. Monitoring serial output, the last message is "JVM Zip Error: C :\jars\dicomToRI.jar.: Fatal error wihile inflating...." Any advice will be appreciated. Equipment: AGFA - DRYSTAR 5300 Reply |
9RepliesFri Feb 04 2022 | Drystar 5300 error self test failure Hello . Drystar 5300 gives me this problem " Error self test failure " on 96 %. How do i resolve this problem . ThanksReply |
1ReplyFri Oct 09 2020 | Not printing, self testing continuously How to fix itReply |
Reliable, low in maintenance, flexible, easy connectivity…these are just some of the key benefits of DRYSTAR 5300. Next-to-application imaging for decentralized applications The unit's small footprint means that convenient next-to-application installation is possible, even in the most space-restricted environments. Its freedom of placement makes it the perfect match for many modalities. With low investment and running costs, equipping every department with its own imaging solution becomes a reality. Excellent reliability, minimum maintenance DRYSTAR 5300 offers all the benefits of Direct Digital Imaging. This solid-state technology avoids the use of complex optical components, making the imager reliable and durable by design. Moreover, DRYSTAR 5300 is ecological and user-friendly. No more wet processing, no darkroom, no complicated adjustments or cleaning procedures. Environmentally harmful chemicals, water handling and disposal costs are things of the past. Easy connectivity for maximum flexibility DRYSTAR 5300 is a DICOM-native imager, which makes network connectivity easy. For point-to-point connection with non-DICOM modalities, DRYSTAR 5300 can be used with Agfa's LINX Paxport™.
| Height | 13.8 in |
| Throughput | 80 films/hour 11” x 14”, 14” x 17” 60 sheets per hour |
| Length | 31.5 in |
| Film Drawers | 1 |
| Power Requirements | 100-240 VAC |
| Weight | 121 lbs |
| Time to First Film | 90 sec |
| Width | 27.5 in |
Printing resolution Geometrical: 320 ppi Contrast: 12 bits (4096) Capacity of supply tray 100 sheets
