AGFA - DRYSTAR 5302
This tabletop, multi-format imager is designed for a decentralised workflow.The unit's small footprint means that convenient next-to-application installation is possible in even the most space-restricted environments. Despites its compact size, DRYSTAR 5302 features two media sizes on-line, with 5 media sizes available. [b]Can be used with following products and services[/b] DRYSTAR DT2 media in blue or clear base. [b] Suitable for following market segments[/b] Mainly regular CR/DR.
FORUMSView All (96)
1Reply5 months ago | Drystar how to fix Tag-tag Problem Equipment: Agfa drystar 5302 Printer Reply |
2Replies8 months ago | stuck in manual mode Please help very urgent Equipment: AGFA - DRYSTAR 5302 Reply |
0Replies2 years ago | agregar formato de placa al sistema tengo impresora drystar solo que le quiero agregar al sistema el formato de placa de 11x14 para poder imprimir Equipment: AGFA - DRYSTAR 5302 Reply |
SERVICE COMPANIESView All Medical Printers/Imagers Companies
Next-to-application imaging for decentralized applications The imager of choice for decentralised applications, DRYSTAR 5302's compact size makes it the perfect match for many modalities. The low investment and running cost of this imager make it possible to equip every department with its own imaging solution. Excellent reliability, minimum maintenance DRYSTAR 5302 offers all the benefits of Direct Digital Imaging. The solid-state technology avoids use of complex optical components, making the systerm ecological and durable by design. Easy connectivity for maximum flexibility DRYSTAR 5302 is a DICOM native image, which makes network connectivity easy. Two media sizes on-line With its two media sizes on-line, the imager offers enhanced flexibility and convenience.
Throughput | 140 films/hour |
Film Drawers | Up to 2 |
Weight | 198 lbs |
Time to First Film | 77 sec |
