Codonics - Horizon GS
by Codonics
Setting the new standard in Dry Imaging.
The Horizon GS Multi-media Dry Imager is an intelligent, desktop size, grayscale output device that produces diagnostic quality medical hardcopy on film and an FDA 510K approved paper in sizes ranging from 14"x17" to 8"x10". Any grayscale media type may be printed to simultaneously. The imager accepts many industry standard file formats including DICOM and incorporates networking, high-speed image processing and spooling capabilities.
FORUMSView All (7)
-Germni
Fri Mar 21 2025
Codonics error -1 SS_impl
somebody help with error codonics, I send to print imaging from RX system and printer appear error
PURGED KEY FEATURE MANUFACTURER 3 DV FILM BECAUSE THE KEY EXPIRED
Replace for other pac film new but the same error, led ALERT on/off  and appear 3 works pending
thanks for advance
-lekgotwaneee
Thu Jan 12 2023
CODONICS PRINTER GS
what could be the cause ?when you insert the film tray in the first slot and an error message "move to 2 or 3"?Reply
-Mouhamed Fadel Diagana
Wed Oct 20 2021
Feature Key
Hi everyone, where and how to buy feature key for printing Media size: 11" x 14" Reply
Throughput78 films/hour
Weight79 lbs
Print Technology: Direct thermal.          Spatial Resolution: 320 DPI (12.6 pixels/mm).          Grayscale Contrast Resolution: 12 bits (4096).          Media Inputs: Three supply cassettes, 80-100 sheets each.          Media Outputs: Three receive trays, 50-sheet capacity.          Media Sizes: 8 x 10 inch, 14 x 17 inch, A, A4.          DirectVista® Film (blue and clear).          DirectVista® Grayscale Paper.          Dmax: > 3.10 with DirectVista® Film.          Archival: > 20 years with DirectVista® Film, under ANSI extended-term storage conditions.          Supply Cassettes: All media is pre-packaged in factory sealed, disposable cassettes.
