Amerex Instruments - HVE-50
Self-contained, portable, top-loading autoclaves with auto exhaust and warming cycle.Amerex Instruments's HVE-50 top-loading, portable autoclave
[list] [*] Space-saving design with lid opening upward. [*] Agar sterilization mode for sterilizing agar and then automatically maintaining it at liquid temperature. [*] Dual-sensing lid interlock prevents lid opening when chamber is pressurized or when temperature exceeds 97°C. [*] Agar melting mode for melting agar and maintaining it at liquid temperature, or for a hot, faster start-up. [*] One-touch lever to easily open and close chamber lid. [*] In-process display shows the status and the progress of sterilization cycle. [*] Door-closure sensor provides a prompt and the cycle will not start unless the door is closed properly. [/list]
Chamber Volume | 50 L |
Internal Diameter | 11.8 in |
Height | 40.9 in |
Chamber Height | 28 in |
Length | 20.8 in |
Power Requirements | 120 VAC |
Weight | 180 lbs (shipping) |
Width | 20.1 in |
Peak Power: 2000 W Temperature Display Range: 5ºC to 137ºC Temperature Warming Range: 45ºC to 60ºC Operating Range (gauge): 3 to 30 psi (gauge), 0.021 to 0.21MPa Sterilization Timer: 1 to 250 minutes
