Amerex Instruments - HRH-110
Autoclave with pre-vacuum cycle and drying by heat and vacuumAmerex Instruments's HRH-110 autoclave.
[list] [*] Fully automatic operation from start to finish with or without drying. [*] One-touch door closing lever opens and closes the door easily, surely and safely. [*] Pre-vacuum cycle - vacuum pump removes air from the chamber when sterilizing solids such as glassware and pipette tips, thereby eliminating cold spots, and ensuring faster and more efficient sterilization. [*] Drying by heat and vacuum increases drying efficiency and reduces cycle times. [*] Additional drying mode for complete drying without having to run the sterilization cycle again. [*] Bacteria filter reduces re-contamination. [*] Lid safety interlock prevents lid from opening during a cycle, when the chamber is pressurized, or when the chamber temperature is above 97°C at which super-heated liquids might boil over when disturbed. [*] Door-closure sensor prevents a cycle from starting unless the door is properly closed. [/list]
Internal Diameter | 16.5 in |
Height | 54.5 in |
Length | 45.3 in |
Power Requirements | 220 VAC |
Weight | 85 lbs |
Chamber Depth | 31.3 in |
Width | 27.2 in |
Peak Power: 3.2kW Construction: Stainless steel SUS304 (chamber) Sterilization Temperature: 105ºC – 123ºC (programmable) Sterilization Timer: 1 ~ 60 min (remaining time displayed) Drying Timer: 1 ~ 90 min (remaining time displayed)
