GE HealthCare - DASH 3000 Pro
by GE HealthCare
Vital Signs/Multi-Parameter
The DASH 3000 Pro patient monitor combines proven durability, advanced user-friendly features, and seamless network connectivity to deliver a reliable and efficient transport monitoring solution. Engineered for mobility and performance, the DASH 3000 Pro supports continuous, accurate multi-parameter vital signs monitoring—including blood pressure, heart rate, oxygen saturation, and temperature—during intra-hospital transport or bedside care.
Designed for clinical efficiency, the DASH 3000 Pro offers intuitive controls, lightweight portability, and robust construction, ensuring dependable operation in high-acuity and dynamic care environments. Its network compatibility enables integration with hospital information systems and electronic medical records (EMR), providing real-time data access for clinicians while supporting biomedical engineering oversight, system maintenance, and interoperability within hospital monitoring infrastructures.
From a biomedical engineering perspective, the DASH 3000 Pro is a durable, low-maintenance solution that enhances patient safety, workflow efficiency, and connectivity in transport and critical care scenarios. (Generated by AI)
0RepliesSat Mar 13 2021 | Codice assistenza Qualcuno sa come entrare nel service? Qual'e il codice? Monitor Dash 3000Reply |
[list] Remain continuously connected [*] Built-in wireless LAN provides seamless network connectivity [*] Exclusive two-way communication allows clinicians to receive alarms and check-in on other patients during transport Quickly transition to and from transport [*] DASH Port docking stations provide one-step connection to the Unity Network and AC power [*] Eliminates need to connect and disconnect leads [*] Provides a secure mount Supports the longitudinal record [*] Patient Data Transfer (PDT) ensures seamless patient record as patient moves through hospital [*] Accommodates over 1,000 beds; doesn't require central station support [*] Connectivity to high-acuity SOLAR® and TRAM® monitors creates a convenient single-source, hospital-wide monitoring solution [*] Admit Discharge Transfer makes admitting a patient quick and easy; reduced manual data entry [/list]
