Microbiology International - D2D Series
by Microbiology International
Double-door autoclave for use in biological safety laboratories, clean rooms and production facilities. Creates a pass-through lock separating sterile and non-sterile areas.
[list] [*] No heating elements and no reservoir for dirty water in the chamber [*] With stand-by pre-heating option, only 10 min. heating time to 121° C with an empty chamber [*] Improved removal of air from the empty chamber via pulsed heating (rapid attainment of optimal steam atmosphere, even without a vacuum) [*] Accuracy better than ± 0.3 C with empty chamber [*] Quicker cooling as neither hot water in the chamber nor the separate steam generator need be cooled [*] After cooling, steam is immediately available for the next sterilization run. [*] Flexible temperature sensor PT-100 for a reference vessel [*] Medium temperature triggering of sterilization time [*] Autofill – automatic filling with demineralized water feed for steam generation [*] Start by clock – timer for programming starting time [*] Collecting point for all outlet pipes [*] Venting valve [*] Baseplate in the chamber for vessels, baskets etc. [*] Validation port [/list]
